Hello All been having some issue starting up my minecraft server and I have no idea what's wrong with the port Forwarding.
Currently I have the server fully up and running and am able to connect through localhost but When my friends attempt to connect after port-forwarding its not letting them.
I'm using a Nighthawk AC2600(R7800 i believe) router
Here's what I've done so far. Not sure what could or couldnt be used wrongly so i covered some stuff it should still be fine for this situation i think but let me know if not.
Imgur link with pics for every step
View: https://imgur.com/a/TGB8Hii
1) I reserved a static internal IP for my Desktop
2)Made sure the PC is running on the internal address
3)Made sure the Server is running on the correct port 25565
4)Setup the Port forwarding with both TCP/UDP
5)restarted router, PC and Server multiple times without success.
6)Checked yougetsignal, canyouseeme and portcheckers and they all say the port is closed.
7) Ran NETSTAT -AN with both server on and off to see if its even trying to listen to the port
Note: The only time the 25565 port occurs in this is with the server on shown but its showing 0.0.0.0 local address so idk if thats correct or should be showing my pc's address
Honestly have 0 idea why this isn't working considering I had a previous minecraft server working fine about 5months ago as well as 2 ARK servers on different ports as well. Any Help would be appreciated thanks
