Hiya all, new here. just upgraded my system, as it was getting crashy
i changed the video card to a new gf4 ti4800se, changed my cpu fan because i thought it was the prob my comp kept doing a freeze, changed soundcard cos freeze had looping awful shrieking sound. could not do the magic crtl+alt+del and had to a reset button push 😀
my current system specs are
1600+ athlon xp
256 SD RAM
ks57a MB
video card as above
SB Live
current temperature of cpu when i run 3d games = 49 cel.
both sides of my casing are open.
unsure of my PSU though. my problem only occurs playing 3d games. just started happening recently when i upgraded to win xp. did a format but still the problem occured.
if i take a fan and blow at the side of my casing, i do not encounter this problem. so.. anyone have any idea which part is overheating and causing the sound loop freeze crash?
also if i can install a big enough fan (not a real fan but a casing fan type) inside would it help? spent alot of cash changing the system to no avail 🙁
any help would be nice and appreciated. thanks
1600+ athlon xp
256 SD RAM
ks57a MB
video card as above
SB Live
