Question Help with the components
Jorge Vaz
67
Hello, Im building a pc and would like to know if the Motherboard and PSU I am looking at are the right choice and if you would recommend me get any other instead in terms of cost benefit also for the motherboard im looking to spend £50-£79 and for the PSU £50-£60 the current components of my build which I already have are: GPU (1660ti) CPU (10400f) RAM (8x2 3600mhz corsair) SSD (256GB) HDD (1TB) I just found out recently that the 10400f has a limiter of 2666mhz but when bought the RAM didnt know about it.
The motherboards I have been looking at are the following:
H510 (link) £69
MSI B460-A Pro £69
MSI MAG B460 Bazooka £72
B560M £74
PSU
Corsair TX550 W 80+ Gold: £52
H510 (link) £69
MSI B460-A Pro £69
B560M £74
PSU
With regards to the RAM speed - you can run that cpu with the ram at full speed if you pair it with an Z series motherboard. You are correct that you cannot run over the rated speed on a B series board however.
PSU looks good, having a look there isn't much in the way of reviews comparing B460 boards, I think for a 10400f you aren't going to run into problems with any of them so it really comes down to what features you need.
Would be great to be able to use the full speed of the ram but might be saying rubbish but is not possible to find a motherboard of Z series between the budget I mentioned of £50-£79 but apart from that Im not really looking at any specific features
There is probably not much point in paying the extra for a Z series board with a 10400f, the performance difference isn't much (ram speed matters much more with AMD Ryzen processors, Intel parts don't gain as much typically). A 10400f + 1660ti is a well balanced combo imo.
If you go with a b560 board, you can run faster ram speeds. It is up to the mobo manufacturer to enable it. You do not want to go so cheap that the VRM's are going to thermal throttle, costing you performance. This board is more than you wanted to spend, but is advertised at running faster ram, with a 10th gen chip.
https://www.asrock.com/mb/Intel/B560M Pro4/index.asp#Specification
PCPartPicker Part List
Motherboard: ASRock B560M Pro4 Micro ATX LGA1200 Motherboard (£98.38 @ Technextday)
Total: £98.38
Generated by PCPartPicker 2021-11-17 14:28 GMT+0000
That PSU is a good choice.
This isn't totally correct. With 2666 ram, a 10400/f loses to an R3 3300x, with 3200mhz ram, in gaming.
When paired with what GPU though...? Most of the test showing these kind of differences are 'CPU gaming' tests - which usually means top tier GPU i.e. 3090 or 6900 XT coupled with 1080p res and low settings to shift the load onto the CPU. With a 1660ti, running at 1080p high / ultra settings it's unlikely to make a difference.
I guess it also comes down to what games Jorge Vaz intends to play, things like CS:GO might actually be played at settings low enough for there to be a difference.
Total: £98.38
That looks like quite a nice option actually, personally I would pay the extra just for the fact it provides room for future upgrades.
That is why you want a board that can get the most performance out of the CPU, from the get go. Many systems see 1 or 2 GPU upgrades, before the CPU gets replaced. Buying good enough, for now, just costs you more money later on.
Reactions: cdrkf
With the board you just sent how do you enable it to be able to use more speed also doesnt the 10400f only use 2666mhz anyways ? So how can that make a difference, sorry if this sounds dumb im really new into this stuff, and related to the games I play tbh is a bit of everything going from league of legends which is a very low demand game to New World which is already more demanding
H510 (link) £69
MSI B460-A Pro £69
B560M £74
PSU
You want a B560 board paired with 2x8GB of 3200mhz RAM for that cpu.
That is incorrect information. You can run that cpu with 3200mhz RAM at the rated speed with a B560 board.
Not all B560 apparently support it though. For instance: https://www.gigabyte.com/Motherboard/B560M-AORUS-PRO-rev-10/sp#sp
  1. 11th Generation Intel® Core™ i9/i7/i5 processors:
    Support for DDR4 5333(O.C.)/ DDR4 5133(O.C.)/DDR4 5000(O.C.)/4933(O.C.)/4800(O.C.)/ 4700(O.C.)/ 4600(O.C.)/ 4500(O.C.)/ 4400(O.C.)/ 4300(O.C.)/4266(O.C.) / 4133(O.C.) / 4000(O.C.) / 3866(O.C.) / 3800(O.C.) / 3733(O.C.) / 3666(O.C.) / 3600(O.C.) / 3466(O.C.) / 3400(O.C.) / 3333(O.C.) / 3300(O.C.) / 3200 / 3000 / 2933 / 2800 / 2666 / 2400 / 2133 MHz memory modules
  2. 10th Generation Intel® Core™ i9/i7 processors:
    Support for DDR4 2933/2666/2400/2133 MHz memory modules
  3. 10th Generation Intel® Core™ i5/i3 /Pentium®/Celeron® processors:
    Support for DDR4 2666/2400/2133 MHz memory modules
It says that on a lot of B560 board specs including the Asus Prime B560 boards yet people aren't having a problem getting their rated memory speed with 3200mhz RAM.
Also all the pc shops near me want me to spend £50 for them build the computer and Im like hell no but at the same time I never have built one by myself so what would be the most reasonable choice
50 bucks to build it, load windows, and drivers is not a bad price. Also if something if DOA they have to take care of it.
Youtube has tons of videos for building a PC.
2 things I would consider would be a case with better airflow it should be fine with the parts your using but if you make a big upgrade for a video card in the future.
I would check the price of the 650 and 750 watt version of the power supply also for the same reason.
Im taking components from another pc which already had an SSD with windows installed so in terms of load windows and drives I dont think they would have to do much
