HELP
halfy
4
Like to know why i can't set my q6600 to 1333mhz and volts 1.4 it keeps locking up..
i have asus p5n32-e sli plus ,8800gtx 768 oc,from factory ,1000 watt bfg ps..
CAN SOMEONE PLEASE HELP!!!!
Are you resetting the memory divider to keep the memory running at default speed or lower? If not, you are likely overclocking your memory too far over spec.
Other than that, the nVidia chipset on your board can be a problem as well. It simply may have a tough time with the buss speed.
