N Noobgamer007 Commendable Dec 19, 2016 6 0 1,510 Dec 19, 2016 #1 Hi, will a gtx 1060 6 gig card be compatible with my amd mobo.plz help
Solution Dark Lord of Tech Dec 19, 2016 Noobgamer007 : Benab3 : It will almost definitely be, yes. Just to make sure though, do you know what your motherboard is? MSI 970 Gaming AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard Yes they are 100% compatible.
B Benab3 Reputable Jan 12, 2015 1,351 0 5,960 Dec 19, 2016 #2 It will almost definitely be, yes. Just to make sure though, do you know what your motherboard is? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,619 1,779 159,590 Dec 19, 2016 #3 Noobgamer007 : Hi, will a gtx 1060 6 gig card be compatible with my amd mobo.plz help What make and model board? Upvote 0 Downvote
N Noobgamer007 Commendable Dec 19, 2016 6 0 1,510 Dec 19, 2016 #4 Benab3 : It will almost definitely be, yes. Just to make sure though, do you know what your motherboard is? MSI 970 Gaming AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,619 1,779 159,590 Dec 19, 2016 Solution #6 Noobgamer007 : Benab3 : It will almost definitely be, yes. Just to make sure though, do you know what your motherboard is? MSI 970 Gaming AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard Yes they are 100% compatible. Upvote 0 Downvote Solution
fry178 Reputable Dec 14, 2015 776 12 5,365 Dec 19, 2016 #7 yes, even that it doesnt have a pcx 3.0 slot. the 1060 doesnt need much bandwidth anyway. what psu do you have? Upvote 0 Downvote
RCFProd Expert Ambassador Dec 8, 2013 12,606 29 56,990 Dec 20, 2016 #8 MERGED QUESTION Question from Noobgamer007 : "Hi, will a gtx 1060 6 gig card be compatible with my amd mobo.plz help" Noobgamer007 : Ok so will any nvidia work on that mobo 100%? FrEaKii : As long as your Motherboard has got a PCI-Express Slot, to fit the graphics card, there should be no issues at all. There is no link to your motherboard + Don't know your power supply model. Upvote 0 Downvote
