Did you remember to remove the plastic on the heat pipe base? The temperatures on a 3600X should be somewhere around 65-75c under "normal" loads like games with a Hyper 212 Series cooler.I just finished building my rig, Im running a ryzen 5 3600x on it with a hyper 212 Black Edition cooler.
On idle I get around 45 degrees and under load I sometimes hit 90, Should I worry?>?
Check what is running in the background. If you have to, do a clean install of Windows and start over with just the basics. Drivers, game launchers, Virus scanner if using one and Browser. It might possibly be a Google Chrome process running, like the hard drive scanner nonsense to "guard itself" from "harmful" programs. That scanning prompted me to switch to Brave which is based on Chrome, but without all the additional spying stuff. https://brave.com/UPDATE: It doesnt matter if Im downloading or not, even if nothing is on CPU just spikes up for example, It's on 48 degrees, spikes up to around 55, sometimes even goes to 65, and as soon as it drops below the 50's it spikes up again
