Question High temps, low FPS and huge drops with RX 470 ?
Nov 23, 2022
I've got myself a Sapphire RX 470 Platinum edition 4gb.
It runs on very high temps even idle.
Idle ranging from 45c to 50c and when in Fortnite for example it goes up to 76..is that normal and safe?
I've cleaned the graphics card and repasted it.
when i look at videos of the same specs as i have, the fps is far higher and more stable than mine.
i don't know if i need a bios update or whatever is the problem..
after running AMD Radeon stress test for only 60 secconds,it goes up to 86 degrees.
My system specs are :
GPU: Sapphire RX 470 Platinum edition 4gb
CPU: i7-3770k 3,5ghz
Motherboard: ASUS P8H77-M LE
RAM: 8gb ddr3
when i look at videos of the same specs as i do,the fps is far more better and stable then mine...
RAM: 8gb ddr3
Pretty normal temps, if it has 0dB/RPM fan options they only start at 50c. You may get better temps by undervolting.
