First, the build:
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($197.82 @ B&H)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard ($114.99 @ Best Buy)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($69.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250 GB 2.5" Solid State Drive ($107.99 @ Adorama)
Storage: Western Digital Blue 1 TB 2.5" Solid State Drive ($109.99 @ B&H)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive ($44.99 @ Adorama)
Video Card: EVGA GeForce GTX 970 4 GB Superclocked ACX 2.0 Video Card
Case: Corsair SPEC-01 RED ATX Mid Tower Case ($147.12 @ Amazon)
Power Supply: SeaSonic EVO Edition 620 W 80+ Bronze Certified Fully Modular ATX Power Supply ($152.00 @ Amazon)
Total: $944.89
Generated by PCPartPicker 2020-05-25 00:52 EDT-0400
Describe your problem. List any error messages and symptoms. Be descriptive.
Recently upgraded from an i5-4460/H81m to the above setup. Fresh windows install.
Extremely high temperatures under load, and semi-high idle. After about 5 seconds in prime95 (small FFTs) I reach 95C. My idle fluctuates between 45-60C.
List anything you've done in attempt to diagnose or fix the problem.
I first took the stock cooler off, and re-pasted. Used the Pea method. Temps were about the same. Then, I bought a Reeven E12 (reviews put this at a slightly better cooler than a 212 EVO), and I added both another front case fan and a fan behind the heatsink (effectively a push-pull setup). I pasted this time with a rice grain shape. Temps are again, identical. Maybe worse. Idle is a bit better, stays under 50C now for the most part.
I'm measuring everything in Ryzen Master.
All the settings on the motherboard are completely stock, the only thing I have enabled is A-XMP so that I can use my ram at the box speed. PBO is set to auto.
I don't know what else to do.
Is the CPU temp sensor broken? I find it hard to believe I was cooling an 84W i5-4460 on the stock Intel cooler WITHOUT all the extra fans and <Mod Edit> I added to my case, and I somehow cant cool a 65w 3600? I am so close to just RMAing the chip or the mobo or something. Could someone help? Thanks in advance.
Total: $944.89
