So I just built a new pc and I'm getting some crazy temps, getting about 60-70c with only 5% load just idle on the desktop and when gaming its going to about 89% and haven't played any longer to not let it go any higher so that's about 10 minutes of gaming.
The Cooler is mounted on the top of the case with the fans blowing up and out the pc through the radiator and the coolant temp sits at about 25-29.
this is the first time I have ever used water cooling so any help would be apricated.
the cooler i just bought is.
CORSAIR iCUE H150i RGB ELITE 360mm AIO Liquid CPU Cooler
and the CPU I bought is
AMD Ryzen 7 7800X3D
I have used 3 different programs to check that the temps are correct and they all say the same I used ryzen master, icue and open hardware master.
AMD Ryzen 7 7800X3D
