Question Home Network Storage over WiFi ?
Cuzzin Chizzy
217
I want to set up home network storage over WiFi and was curious on what some good options would be.
My goal is to have a large amount of storage (at least 16TB) that I can access the data on from my home PC, my phone, my laptop, etc., from anywhere in the house.
Would I want something like a RAID drive/enclosure that I plug into my router/modem?
or is there some other equipment I'd need to get a home network like that set up?
Ideally, what you want is a 2 or 4 bay NAS device, connected directly to your router via ethernet.
QNAP or Synology.
All your house devices can access that, through the router. Be they wired or WiFi.
Reactions: punkncat
QNAP or Synology.
Thanks for the info USAFRet !
I was also thinking about getting a raspberry pi or another pi like device to have on all the time for Home Assistant. I don't always keep my PC on all the time, so can't really use that as a "hub".
With these NAS type units, are there any that would have a basic operating system on em that you know of where I could install something like Home Assistant? Or am I best off keeping the 2 goals separate?
Link to this "Home Assistant"?
QNAP and Synology have their own OS's, typically a Linux variant.
And come with a WIDE array of installed or available applications.
