home theater to pc problem
angelzheravinski
Hi i am trying to connect pretty old tcm 5.1 home theater system i have cd input aux in and digital input on it and my pc i have 6 auido connecters dont have optic cable.I tried to connect aux system to pc and select it as headphone stereo...but i get sound only from 1 speaker i don't wont full surround sound just to get sound from all speakers...
thee_prisoner
1,136
It would help if you post your motherboard model. I'm assuming "tcm" is a Bose model(which model?).
Run a cable out of the green output using a "Y" cable with rca(red and white) plugs into the aux.
With little information I'm guessing that you need to go into windows audio setup and if your mother board is using Realtek sound chip, you need to configure both. realtek should have an option for speaker fill that will play sound out of all speakers.
An inexpensive option would be to use a sound card if you have a free PCI express slot open. This card has an optical out and can do surround sound if you want to in the future. http://www.newegg.com/Product/Produ...102063&cm_re=soundcard-_-29-102-063-_-Product
Happy listening, the Prisoner...
