Homemade water cooling Case (DIY Fan Controller)
Page 4 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
Now on to my DIY SUB
Currently i modded my Sound blaster Audigy Value 7.1. Installed new Op-amps Burr-Brown OPA277 and Capicitor mod.
It improved sound quality a lot...But now i think i Should have new SUBWOOFER..
So here i am with my own Power Sub-woofer.
DIM:-
14inc X 14inc X 18inc Sealded Encloser made from 1/2 inc thick MFD board.
12inc - 4ohms - 800Watts Sub- drive
home-made 450watts amp.
Have a look
SUB
http://img509.imageshack.us/img509/8318/sub02it1.jpg
Its very enjoying Playing CRYSIS with this subwoofer.
Thanks Nuke
Well i studied online about Sub-woofers and made my own box.
And for poweramp, originally i found it on a Turkies Site, i redisgned the amp with some part change like driver transistor and few pf change..Amp is having 8 Darlington Transistor in Power stage.
Darlington Transistor are it self a pair of Transistors in a singel pack. So in real it is having 16 Transistor... Very power full
http://www.st.com/stonline/products/literature/ds/4132/tip142.pdf
Around Dec 2007 i first decided to throwaway my old metal pc cabinet and buy a transparent case.
But when looking on rate of transparent cabinet in India ...It was too high.. Then i though why should't i make my own case.
Since then my rig modding is continue..... Adding new mods ...
Thanks Mr. Blackpanther26
Glad I can just buy stuff and make it work, but very well done! One reason so many peeps like him come to the USA with UBER engineering skills. Smart guys get all the big bucks.
I have made the waterblock for my HD4850 GFX Card.
Have a look. 100% passed leak test.
Will test it on sunday... Hope to give you performance report soon.
Thanks for your reply...........
I have done all Galvanic Corrosion calculations according to cathodic area , metal conductivity and metal thickness for Copper and Aluminium with Anti-corrosion water coolent ... it results to about more then 30 years for this block.....So NO worry...
Stock cooler is removed from HD 4850 , tonight hope to fit this block and run some tests....
Posting results soon....
Thanks ones again
