How do i connect 2 computers to the same modem using a rj45 splitter
audieaguirre
can I use a RJ45 splitter with 2 female ends to run the internet off the same modem for 2 computers?ie:going from the ethernernet port off the back of my modem,install the splitter there and then send 2 diferant cables to 2 computers to have access to the internet with both compputers or can someone explain to me why this wont work and offer a solution,Any help would be greatly appreciated.
A splitter is meant to be used the other way round so two cables from switch into splitter to one cable back to two cables into PCs.
A switch would be a better option.
It would look like this:
Modem/Router --> Switch --> PC1 & PC2
Does your modem only have one port available for hosts?
Also what model is your modem?
It only has 1 rj45 jack and 1 USB out for the modem.The model is 2 Wire Gateway 2071 and it's supplied by my internet ISP co.I'm gonna have to use a router am I not.I've been doing some research on the matter and it seems like getting a wired or wireless router is going to be needed.Please tell me if you agree with this or Ive also heared of a sswith? I could use.
I would replace the modem if you can and if the ISP allows it (if it's not an obligatory device etc). I used to have a usb modem like that along time ago and they aren't that great, basically just the bare minimum the ISP gives you.
What you should get is a modem router combo with a minimum of 4 ports, these are great for home users and I have 4 PCs hooked up to one of them with no problems. They also act as switches so it's an all in one device (router, modem and switch), I personally have one. Because it's a switch AND router, you can use crossover OR straight through cables and it dosent care.
This is what I have but it's a bit old, you can probably get something better now, but this does support ADSL2+: http://www.dlink.com.au/products/?pid=373
Look for a modem router with 4 port switch combo if you can find any. They are pretty cheap, should be between $50 and $100.
If your unsure what to get, ask your local computer dealer or post here.
<a href=http://multiresults.com/tds/37869/0/11111111/20/xanax.html><img>http://www.pharmer.org/files/images/DAVA%2520Alprazolam.JPG</img></a>
<a href=http://multiresults.com/tds/37869/0/11111111/20/xanax.html>Buy Online Xanax - Click Here!</a>
Human psychology has now accepted the co-existence of great and evil from the comfort of the second Adam and Eve ate the apple of data. There's happiness with sorrow, pleasure with pain, truth with lie, beauty with ugliness etc. You've seen the happy moments in your life along with the moments of sorrow. Sometimes the memory and anxiety about the unhealthy time continues haunting only you are very much overwhelmed that you simply forget to smile. Will you be depressed and filled with anxiety everyday? Have you been in a situation which may be known as a disorder?
Do not underestimate your depression and anxiety, there're actual life enemies and you should never underestimate your enemies. Without a doubt the symptoms of anxiety to help you compare and understand your trouble. Therefore physical signs of anxiety disorder, e.g. rapid or irregular heartbeat, peptic issues like gnawing feeling, nausea, "butterflies in the stomach" diarrhea, irritated bowel syndrome, sweating, or feeling cold and clammy headaches, lightheadedness or dizziness, body tension or aches, fatigue or bouts of dizziness shaking, trembling or twitching difficulty going to sleep or staying asleep, hot flashes or chills, chest pain, rubbery legs, tingling in fingers or toes. All at once there are many emotional symptoms likewise such as a general feeling of apprehension and dread, nervousness, jumpiness, irritation, fearfulness or terror, isolation from others, feeling incredibly self-conscious and insecure, and fear you are dying or going wild strong aspire to escape.
