Hey,
I have posted images to imgur for reference View: https://imgur.com/a/WrdJYYd
I have a few question's that the community might be able to help me with. First being my loop. I'm a greenhorn when it comes to this fancy water/liquid cooling stuff lol. With that said I was wondering if someone could walk me through draining my loop. I've watched Jayz video on draining loops, I understand the just of it, but he says to never completely drain the loop as it could burn out the pump. And.. well.. I don't typically want to do that as you could guess lol. Reason why I want to completely drain the loop is because I bought this system pre built and the guys who put it together used soft tubing. In any other circumstance I wouldn't have a problem with it, but with my case I have a top mounted 360 mill rad and on the exhaust side of the case I have a 120 mill rad one feeding the processor, the other feeding the 1080ti.
Again, I'm new to the water/liquid cooling world so bare with me. But when I look at the loop there's one straight tube going from the bottom of the rez to the inlet (I'm assuming) of the 360 mill rad. Than the exit on the 360 mill rad feeds the inlet on the waterblock to the cpu. the exit on the waterblock to the cpu than feeds the inlet to the 120 mill rad, the exit than feeds the inlet to the 1080 ti, than the exit from the gpu cycles back to the rez. With that said All of this is fitted into a full ATX case the exit from the waterblock on my processor feeding into the inlet on the 120 mill rad that tube is (and I kid you not) less than a millimetre from touching a fan on the top mounted 360 mill rad. So in the summer when the heat rises the tubing expands and it starts to rub against said fan.
This is why I'm asking the community for guidance and assistance to draining my loop. Because I want to drain it and swap out the soft tubing for clear hard tubing and because I want to drain the colored liquid that's in it for distilled water. I should mention that I DO have a jumper from my power supply.
**P.S I know I need to clean my pc. lol
Parts:
- XSPC full liquid/water cooled loop.
-Deepcool Genome GamerStorm II (case)
-ASUS ROG Maximus IX Code (Mobo)
-i7 7700k
- GIGABYTE Aorus GeForce GTX 1080 Ti Waterforce WB Xtreme Edition 11G GDDR5X (GV-N108TAORUSX WB-11GD)
-Seasonic 1200 watt power supply
Parts:
-i7 7700k
