Ok i am having issue's here...I went into CCC advance to crossfire my 2 cards and my ati CCC doesnt even have crossfire in it can someone help me through this so i can enable my crossfire please. I am using windows xp.
You only need a single bridge. Also, what cards are you using?
Also, go check in the hardware manager and check the status of the cards. Vista disable the first card sometime to install the second one. Enable it if it's the case and you should be ready to go.
i am using 2 4850's and i am currently using windows xp.
oh my i never thought about that grrrrrrrrrrrrrr. that is the mother board i am using.
now what do i do can i sli 2 ati cards or dos it have to be nvidea?
Nope you cant, SLI is with nvidia cards, and crossfire for ati
well you have a few options,
Sell that mobo and get a crossfire capable mobo (imo the best thing to do, if you want to keep your 2 cards)
sell both your 4850, and replace em for 2 gts250 or some sort
Or replace the two for one single gpu solution like the 4850x2 (this is probably the cheapest route, but it means sellling your current two so not the easyst)
