[SOLVED] How do i know if a gpu case hole will line up or not ?
LowEndPC1234
49
I Want to buy a PC casing (Just replacing PC Casing), But i don't know if the GPU Case hole will fit or not. Anyone know how to see if the GPU Case hole will line up or not ?
there's also case that have very similar size to my PC casing that i'm using right now, it will fit, right ?
As stated before, if you have a standard PC case it will fit the standard motherboard of the size the case was made for, and most smaller ones. So full ATX will fit smaller ATX cases (as long as it's not a custom case from an OEM vendor where they did not drill the holes for the stand-offs in the case).
Since all motherboards will have a x16 graphics slot that is standard, you are ok.
The openings are an ATX standard.
If your graphics card is unusual, say with a 3 slot width, then, there might be an issue with a ITX.
motherboard.
What is the make/model of your current case and the prospective replacement?
Will ASUS P5G41TM-LX line up with this case ?
