Question How do I power my CPU?
Sep 29, 2019
8
It's my second build. I had no issue with the first one years ago.
However this time, it doesn't work. I have a black screen when I turn on the computer. The fans are running though. I'm pretty sure it's because the CPU has no power.
My motherboard is:
Gigabyte Z390 Gaming M (M-ATX) mb4608.
It has a 4-pin ATX12 V 2x2 and a 8-pin ATX 12V 2x4 side by side.
My power supply is:
Oultech 80PLUS SILVER ATX Power Supply Unit FSP RAIDER Series, RA2-650
It has a 2 4-pin split connectors. I think I can make a 8-pin connector if I combine them but I'm not sure how to plug it.
Should I plug 1 part of the 4-pin connector on the 4-pin ATX12 V 2x2?
Or should I connect the whole 8-pin with the 8-pin ATX 12V 2x4?
I hope someone can help me.
Sep 29, 2019
8
Are you using a graphics card? If yes, make sure that the monitor is connected to it, not to motherboard. If not, you'd need one. The onboard does not work.
I was plugging my monitor using the integrated HDMI port. The onboard graphic card does not work? How come? Why is that?
I tought I would not need one so I don't have any :-(
Sep 29, 2019
8
The CPU does not feature integrated graphics and the video ports on motherboard rely on it. The board itself does not feature a video controller. It's integrated in the CPU, which is not the case with the CPU you're using.
https://www.tomshardware.com/reviews/intel-core-i5-9400f-cpu-integrated-graphics,6107.html
I see. Thank you very much for this information. I didn't know that.
Would you have a suggestion for a cheap graphic board?
Sep 29, 2019
8
I think I will go for this model instead:
MSI GeForce GTX 1050 Ti 4GT LP Graphics Board LP Model vd6238
It's even cheaper and it's probably good enough for my needs.
Sep 29, 2019
8
It works!
However, when I try to install Debian, I get a black screen as soon as I click "install"...
If I boot using a Live USB Ubuntu 18.04, it runs normally. So I might have to change my Linux distro.
That sucks a little bit.
