Question How do these fans connect?
Feb 20, 2019
4
https://www.amazon.co.uk/CiT-Mid-To...UTF8&qid=1550695958&sr=8-2&keywords=Cit+BLAZE
Hi, i'm looking at getting a new case but don't want have to buy anything for it all to work. I have found a case i like(linked above)but i am not sure as to how the fans are connected. I cannot tell if each fan requires a connector to it or if all the fans are connected(i.e they connect to each other) to one connector(i.e the 3pin/4pin).All help appreciated.
I think it is all separated. You will have to put that question on the product Q&A section, but if it is all separate and your motherboard doesn't have the right amount of fan headers, you could buy a fan splitters for about £6 ( $7-8 estimated).
