Umm, not to invalidate the time you spent looking for a loophole in my debate and stand then trying to draw me into an ambush ;-).
But amds properly specified thermal protection runs automatically, and you do not set a temprature for it to shut off at.(and if you do ((which you might I am not sure if amd specified protection allows you to change that temp)), however any temp below 90C will suffice as the protection runs independant of the possibly locked processor.)
Make no mistake(ugh dubya comment) the method you described is what you do for SOFTWARE thermal monitoring, not for amd specified thermal protection(which to date has few supported motherboards I am aware).
That is all, resume your attempts to destroy me ;-).
Those things can eventually lead to instability. W/O having a freeze, what do you set the thermal protection at? How hot is too hot?
PS: for all intents and purposes instability=lockup. JUst to clarify, if you have instability(crashing apps etc) those are covered by my use of the term "lockup"(meaning programs etc).
As for your what do you set your thermal protection too? The best way IMO is to download toast, and set the cutoff 2 degress F higher than the temp you reach with that app.
YOu will most likely NEVER stress the cpu temp to that level, but if your playing quake 3, and your cpu shuts off due to your software monitoring, but you didnt have a crash, raise said temp another degree.
But I am digressing, my point is made my honor defended, adieu.
The Cash Left In My Pocket,The BEST Benchmark
