How long does the gameboy advance battery last for normaly
G
Guest
Guest
Archived from groups: alt.games.video.nintendo.gameboy.advance (More info?)
Hello,
Im thinking about getting a GBA how long do the batterys last for if you run
original carts. I've read that if you use flash roms the battery life is
about 7 hours.
Thanks.
On Thu, 3 Jun 2004 17:19:07 +0100, "Krell" <some@onentlword.com>
wrote:
>Hello,
>about 7 hours.
Flash ROM tended to draw more than mask ROM. With original GB, GBC,
and GBA game, the battery should last around 10 hours on a set of AA
batteries.
To reply, replace digi.mon with tds.net
Thanks. Also do games play with higher fps on real gba than on emu do you
know?
"Impmon" <impmon@digi.mon> wrote in message
news:4rmub0l14d1ap7h1c6vk32251clhqotr11@4ax.com...
> wrote:
> >Hello,
run
> >about 7 hours.
> batteries.
On Thu, 3 Jun 2004 19:59:40 +0100, "Krell" <some@onentlword.com>
>know?
That depends but usually games are the same on real GBA and on
emulator. If you have a really fast PC and turned off any limiting,
the game would be much faster on PC than on GBA.
