How much power does it use?
G
Guest
Guest
I would like to know how much power I would use if I have 300w power supply that supplies power to components (cpu,ram,grafik etc.) that use 180w.
How much power would I be using in that case 300, 180 or maybe something in between?
kurokaze
421
if the sum of your components suck up 180W,
you'll probably use somewhere around that
value.. IMO
Intel Components, AMD Components... all made in Taiwan!
FatBurger
Illustrious
It depends on the setup, though. If you have 5 hard drives, and no CD-ROMs, a low power video card, and nothing in PCI slots, you'd still need a 300w+ PSU, because you're using a lot of a certain voltage.
Apple? Macintosh? What are these strange words you speak?
G
Guest
Guest
thanks for the replys
I was wondering if a 300w psu would use more electrcity than a 250w psu if it contained the same components?
using less electricity is good for my economy and the environment
<P ID="edit"><FONT SIZE=-1><EM>Edited by jenspetersen on 06/26/01 12:30 PM.</EM></FONT></P>
peteb
2,584
having a larger power supply may itself use a little more power, but generally I'd say a large power supply is going to be more efficient than a small one.
If you run a 300W supply at a high load it must work harder, generate more heat and generally be less efficient. The larger PSU has more capacity and works less to run the same amount of kit...
-* This Space For Rent *-
email for application details
lhgpoobaa
Illustrious
Dec 31, 2007
14,462
electricity leaking from the walls???
stopit!
your scaring my hamster
*laughs*
My Hamster doesnt like sarcasm. He may very well bite you in your hard to reach places!
FatBurger
Illustrious
What he says is probably true, though. Larger power supplies would use less effort, so they might be more reliable.
Crashman
Polypheme
Former Staff
Yes, I usually recommend double the needed size simply because the rated sized is peak, not continuous, and with the numbers fudged. I just was letting him know that even if he got one four times the size he needed, it would only output as much power as the system used, so it wouldn't affect his electric bill.
Cast not thine pearls before the swine
Crashman
Polypheme
Former Staff
HERES where it gets complicated. I use a commecial grade 250 watt power supply. It has higher nominal ratings than most 300 watt ordinary power supplies. So I usually reccomend that anyone serious about their power supplies read the fine print-they will tell you what amperage each voltage is rated at. How much you need of each depends on your configuration, but concerning fans, most people do not need to worry about the 12v circuite.
Look for a rating of at least 15A on the 3.3v for typical systems, 18A on heavily equiped Athlons. 25A on the 5.5v is usually adequate. Since these are shared, the combined wattage should be at least 150W. I have never seen a power supply that would not supply enough 12V current if it met those other requirements.
