Question How to check how much watts is my computer using?
ipwn3r456
851
26
I want to know if there is any software that can detect how much power my system is using, because I am curious about power consumption. Is there a software that can detect how much power my system is using? Or do I have to buy one of those power meters?
randomkid
2,846
169
If your intention is to measure power consumption in real time, I would say you would need the power meter. I know of no software that can measure but on the other hand, I haven't really looked yet. It is interesting if someone can give a good answer here.
In the meantime, you can use this to estimate but definitely its far from what you want:
http://extreme.outervision.com/PSUEngine
ipwn3r456
851
26
Do you any softwares that can detect power consumption? Thanks for the link.
clutchc
Ambassador
No, I've never known of any. That doesn't mean there is none. It just means I never heard of any. Still, I would opt for the meter over any software that may/may not be available. Just keep in mind that the meter will show a slightly higher wattage than the computer is actually using. Plus, the meter will provide other interesting information pertaining to Amperage, Voltage, power cost, etc. And, you can use the meter on any outlet for other devices as well.
ipwn3r456
851
26
Are power meters usually accurate? Like how much percent?
dudewitbow
Dignified
I know there was some program that caught my cpus amperage and voltage(in return, gets you wattage) from one of my installation cds but not the gpus consumption and the rest of the systems consumption
dudewitbow
Dignified
its not enar 100% accurate, since one:
there is no psu in existence that is 100% efficient(even platinum rated psus are only ~90% efficient). efficiency depends on the different levels of loads. the reason why the wall wattage is higher is because the psu is accidentally turning some of the wattage into heat rather than electricity
ipwn3r456
851
26
I already have a program that detects the power consumption of the CPU. That's why I really want to see if they actually have those softwares that can detects system power consumption.
ipwn3r456
851
26
Nice to know that. Thanks.
ipwn3r456
851
26
0.2% accuracy? That doesn't make sense at all. More like its 99.8% accuracy. I don't think power meters are not that low accuracy...
ipwn3r456
851
26
Oh. That makes ALOT more sense. Never thought those meters are that accurate. I was thinking like 90 - 95%... But i checked the item on amazon, it said up to 15 amps... computers use more than that... Will it works still on computers?
That's 15 Amps AC not DC. A normal home power outlet can only provide 20 Amps AC, and any normal PSU would never pull that kind of amperage (I don't know of any normal consumer grade PSU's that DO actually).
ipwn3r456
851
26
So it does work with computers right? Sorry I am not good at stuff like these...
HeroicKevin92
28
http://research.microsoft.com/en-us/downloads/fe9e10c5-5c5b-450c-a674-daf55565f794/
Here you go boss man. Sorry I'm late :D
ipwn3r456
851
26
I wasn't expecting someone to reply this that late... I got myself a power meter now, so everything is fine. Thanks for the suggestion though.
prime38time
if you live in the states this would work quite well.....otherwise purchase one to work in your country's power grid
RoamingDog
If you have a good quality UPS (and you should), it may include power consumption among the things it monitors. With a USB connection you can log the usage information.
Otherwise, for less than $20 you can get one of the Kill-A-Watt P3 meters.
