Question How to connect 4 pin gpu fan to 2 pin connector?
Kunalsehgal
41
Hello Guys,
I recently cleaned my PC and also the 1050ti GPU which has 2 Fans completely by disassembling each part including fans, board, heat sink and changed thermal compound. But after assembling back my pc and running it, one of the GPU Fan is making noise and wobbling. I shouldn't have cleaned the fan deeply, I should have just remove the dust lightly, but I tried cleaning the dust with Isopropyl alcohol.
So at my place where I live, I'm not able to find a 2 pin GPU Fan but 4 pin. Can anyone tell me is there any way I can connect a 4 pin GPU Fan to 2 Pin Connector?
Can you elborate on how you deep cleaned the GPU and it's parts? Might want to include pictures to help add more meat to the potatoes, if you will.
i used to do that but I've since learned, courtesy of my colleagues, that it actually denatures plastic over time. I use a fine bristle painters brush to dislodge dirt/debris.
