I just ordered the Fractal Define 7 case with 2 more Noctua fans(NF-A14 industrial 2000rpm) to build this push/pull setup with my H115i Platinum watercooler. I have some questions about the correct connections of the fan headers. With my current case and setup (front rad push) I have these 2 same Noctua fans in front of the rad connected with a Y splitter to the CPU_FAN header because I didn't get them to work connecting them to the Corsair waterpump headers. There seems to be a PWM compatibility issue with these specfic Noctua fans(especially the 3000rpm version). Only the stock fans seems to work with it. The pump header is connected to CPU_OPT. The Define 7 has a fan hub and my original plan (like the manual describes) was to connect the 4 rad fans like this:
I would think having both push/pull fans on the same height on the same header(y-splitter) so therefore at the same rpm and would be the most benificial? Or doesn't really matter?
I also wonder if I need to use the Nexus fan hub that comes with the case at all for this because a lot of people on forums seem to stay away from fan hubs that comes with the case and just use MB headers only. But for that my MB has only 3 case fan headers and I'm not sure how I should set it up with 7 fans in total(all PWM: 4 push/pull, 2 on top, 1 on the rear) if it's not recommended to use the case fan hub. My GPU has 2 fan headers as well but these are not controllable through BIOS and AI Suite I guess. Thanks a lot in advance.
