How to connect joy stick Saitek X36F to computer
alwaysintrouble
Hello,I am looking for instructions on how to reconnect my Saitek X36F/X35T combo to my pc.I haven't been able to locate any information on how to do this. I don't need the drivers. I need the info on how to conect it back to my pc
This topic has been moved from the section Forum Feedback to section Computer Peripherals by Grumpy9117
computer perepherals such as gamepads, controllers and joysticks are all connected via usb. just plug the device in and install the software that comes with them. they should work perfectly fine with very minimal effort.
if the device is a non-computer perepheral then theres a chance it might work, but its on a case by case basis. more often than not its more hassle than its worth.
