Question how to fix check cable connection
Aug 29, 2019
hello i have a lenovo laptop last day i want to change the windows i put the windows dvd on it and want go format all drives but the windows drive doesn't get format so i delete all participations and make a new partition and start to change windows but then it say cant find files and then restart the installation I turned it off and again i want to change the windows but now on boot it say intel undi pxe 2
i research on the internet and they say it probably for hard drive but i check bios and it recognize the hdd and it write the hdd model what should I do?
That is for network boot. You should disable network boot in bios.
And learn, how to use punctuation marks. All your text is one big sentence. Really hard to read.
hello I just want to cover all the story
hello i just want to cover all the issues I disable pxe from bios but now when i put windows dvd on it it just show lenovo logo and then screen goes black and again show lenovo logo and repeat
