Question How to fix intermittent black ink problem on Canon printer ?
new_ user
19
Hello
Printer model : Canon PIXMA G2410
Every time when I print, on the first sheet always the black color is not clear, then starting from the second sheet it prints normally.. Sometimes starting from the lower half of a sheet the black returns to normal.
This only happens with black, the other colors are fine , any help please !
Run a deep head clean for all colours. Try printing in greyscale only and see results, then print in colour so it uses the small black cartridge, thats if you have a four cartridge printer from within the printer properties section and see if the first page prints correctly both times.
I did a deepclean both for black and colors and the result is the same every time i start printer the black is not clear and after 1 paper or from half paper the black retrun to be printed fine , strange , as i can unserstand it is somehow printing from cold status that causes this problem.
In the printer properties advanced tab, there should be a tick box to 'Enable Advanced Printing Features'. Just untick that box, then apply and ok buttons. Then try a print test again. I had weird things happening before with this setting ticked. Turn printer off and back on if it has not changed after applying.
Let me know how it goes.
In the printer properties advanced tab, there should be a tick box to 'Enable Advanced Printing Features'. Just untick that box, then apply and ok buttons. Then try a print test again. Had wietd things go on before with this setting ticked. Turn printer on and off if it has not changed after applying.
Here are the 2 test pages. As you can see, the second test page is the best one:
https://www.mediafire.com/view/unaw0j1j3fl853b/1test.png/file
https://www.mediafire.com/view/j0sgmbdrapsfbnn/2test.png/file
Could be something like, as you mentioned, being "cold" and then warming up.
Do you know anyone else who buys ink etc. from that store? Are those people having ink and printer problems?
Very likely that the ink is substandard and does not meet Canon's formula and quality requirements. Could be completely counterfeit - no way for most stores to determine that barring customers bringing back failed ink cartridges.
My thought is that the ink dries out and otherwise degrades around the print heads and it takes a couple of pages worth of printing to clear/clean out the print heads.
Pri nter manufacturers design their printers to use manufacturer's brand inks. Ink is a profit center for the manufacturers and it is often touted that printers are sold a loss. A loss that is recovered via ink profits.
And using other inks likely voids any printer warranties.
Unfortunately that is the way of things and barring some general consumer revolt - not much can be done about it.
[Note: Some third party ink/cartridges may be good and work well. Even if "new" or "refill'/"refurbished" etc.. May work for awhile..... I gave up on Canon products when I could no longer even move identical Canon ink cartridges from one Canon PIXMA printer to another of the same model.]
Try what you can per suggestions above and determine if anything else makes a difference.
Then try another cartridge - legitimate Canon if possible. Also take a look at the ink absorber pads if possible.
Is inky residue spilling out? There are videos (of varying quality) on line.
Overall, the likely culprit is the ink.
Reactions: new_ user
Have you tried the saucer of water trick. Sit the black cartridge ink head in a shallow saucer of warm water to see if ink leaks into the water. This helps clean and maximize the flow through the head. If you see a good flow of ink into the water, quickly wipe the head with paper towel or tissues and put it straight back and print. See if it prints the whole page.
thank you very much for details and for you time , I will try to purchase a black ink in comming months is possible and empty the blakc cartidge and refill it and see the result ,
i will consider to buy epson printer next time avoid totaly canon
Your photos show flaws in the TOP half of each line for Black ink only. That means the ink is not getting onto the page from the TOP jets of the Black printing head, but IS working in the bottom jets. This is NOT a failure of ink flow from the ink tank to the head. It is temporary clogging of those top jets only in the Black print head. While that MAY have been caused by off-quality ink, merely changing the ink in the tank will not fix this. You must find a way to clean those clogged jets.
See the Set-up manual for this printer, p. 1, Find it here
https://gdlp01.c-wss.com/gds/8/0300029398/02/G2410_G2510_GS_E7e_V2.pdf
Stage 3 details now to install the two print heads in the carrier. The RIGHT-hand one is the B (Black) print head. CAREFULLY unlock the tab for that and lift the head out of the carrier. You can try two cleaning steps.
1. Use a wet paper towel or tissue to wipe gently over the inky face of the head where the microscopic jets squirt out ink. Do this repeatedly with cleaner wipes until the front face is clean and gives you a black stripe on your wet tissue.
2. If necessary, make one tissue really wet and place the print head, print jet side down, on that wet tissue and let it soak for a while. Then lift it off and wipe clean.
DRY the print head with a clean tissue, leaving no junk on it. Replace that head in the carrier and lock it down.
See Stage 4, four steps on p. 2. to verify the system is OK. Skip to p. 3, Stage 6 to check all is well. Now use the printer's menus to do a full Ink Jet Cleaning, then print test pages.
Assuming this all went well you will have proper printed sheets. But the real test will be after you shut down and do not use for a day or two, then try again.
Hello thank you so mucj ; I will try to remove the head and clean it as describe ,may be in week end an I will post the results , thank you I m realy grateful
I think my problem is solved after getting a wired new one wich is , after making some couples printing the print is excellent but when performing a copy black have some veritical line so i try to remobve the head and clean , and i mad some heavy printing in color and black and now eveny after a cold start it seems working fine , so thank you so much for helping
I have a final question hopfuly , where i can increase quality copy from the print using only the boutton as lcd show a and c and f
thank you again
I could not find a manual for that printer on-line. The best I could find was a set of video tutorials for it here.
I looked at the "Colors are Uneven of Print is Faint" one and it details how to do two levels of print head cleaning. You may have done that already. Further, that is how to fix prints that are missing certain parts completely, and that is what your ORIGINAL post was about. Your most recent post sounds more like parts of the print are just faint and you would like it darker and with more ink on the page.
Net result is I do not know the menu system in your printer. So IF the menu appears to offer those three options for PRINT QUALITY, try each of them try see what they do. The may change the ink density as you appear to need, or they may change resolution, or one chose may be black and white only. Or perhaps there is another menu item related to print quality and intensity of ink on the page.
