Hello all.
I purchased a refurbished Aorus Z390 Mobo and RGB 120mm fan that I believe is 5V. The mobo is working and the fan is installed and moving air. But the fan lights aren't working. I have RBG Fusion 2.0 installed and the Mobo colors are changing. I did connect the RGB fan to the RGB header but because the Mobo was purchased refurbished I am wondering if I needed to do something manually to the Mobo to activate the LEDs? I did find the manual online and the LED section talks about a jumper... ? Anyone have any ideas?
Thanks.
Thanks.
