How to make god's abilities obtainable?
G
Guest
Guest
Archived from groups: rec.games.roguelike.misc (More info?)
Hi,
As far as I remember it's my first troll that went so deep.
But the problem is that I cannot make use of Zin's (or maybe
Shining One's) abilities because my chances are bad (Holy Word)
and very bad (Guardian Angel).
The dump follows.
And one more interesting idea: I found silver statue that let
me earn 4000 XP: I moved to it, waited for the demons and
stepped back. Then in my god's name I killed the demons. Well,
it was not-so-fair, so I destroyed the statue.
Tomasz
Dungeon Crawl version 4.0.0 beta 26 character file.
// I used to play for 30 or so minutes every second
// or third day; now Wrok may be 1 month or so old.
Wrok the Hacker (Troll)
(Level 18 Fighter)
Play time: 12:15:11 Number of turns: 46955
Experience : 18/312551
Strength 37 Dexterity 6 Intelligence 6
Hit Points : 164/185 Magic Points : 18
AC : 24 Evasion : 6 Shield : 0
GP : 2220
You are in the Hive.
You worship Zin.
Zin is exalted by your worship.
You are hungry.
Inventory:
Hand weapons
a - a +6,+6 executioner's axe of chopping (weapon)
// Found at 4th or 5th level!!! Was 0,0, I enchanted
// it myself.
b - a +6,+5 bow of flame
// Found it already +6,+5.
c - a +4,+4 bow of frost
// And this one was 0,0 too. It's great for lava snakes
// imps or fire-demons.
Armour
T - a +2 storm dragon armour (worn)
// I found the armor, no need to kill the dragon. Well, I killed
// already 2 storm dragons, but they didn't leave the hide.
Jewellery
e - a ring of sustenance (right hand)
// Pretty important for the trolls.
You have 9 experience left.
Skills:
+ Level 11 Fighting
+ Level 16 Axes
- Level 5 Maces & Flails
+ Level 9 Bows
+ Level 3 Crossbows
// Ran out of arrows but found the bolts. Not it's off.
+ Level 7 Throwing
+ Level 5 Armour
+ Level 14 Dodging
// Is this worth anything when wearing heavy armour?
- Level 1 Stealth
- Level 4 Unarmed Combat
+ Level 1 Spellcasting
+ Level 4 Evocations
You have 19 spell levels left.
You don't know any spells.
Mutations & Other Weirdness
Your mind is acute (Int +1).
You are partially covered in supple grey scales (AC + 1).
You are protected by plates of bone (AC + 2, dex - 1).
Your system is immune to poisons.
// I found no ring of poison resistance!
You digest meat inefficiently.
You have a slow metabolism.
You are clumsy (Dex -1).
You can control translocations.
Space occasionally distorts in your vicinity.
You have supernaturally acute eyesight.
You can teleport at will.
You can spit poison.
You have a pair of small horns on your head.
You are robust (+10 percent hp).
// I had -10% of HP... I ate every shapeshifter that I met until
// I got some pretty set of mutaitons. Now I'm happy with ones
// that I have now so I keep off the shapeshifters. BTW: for the
// first time I found the level divided into the rectangular
// chambers; almost every chamber had 1 shapeshifter and one
// "standard" monster. This way I got pretty lot of mutations.
Tomasz .-- .-. --- - . ---...
> Hi,
AFAIR your chances are modified by your ivocations skills - use the
simplest god abilities when you have free exp to spend and your Invocations
skill and chances will raise (not so fast for the best of them).
> The dump follows.
Personally I don't think it's cheating - just opportunity.
Hehe, every point into strength I guess.
> Inventory:
> Hand weapons
>// it myself.
Very lucky, helped much as Zin is not really helpful in general fight IMO.
> Jewellery
Well, I wouldn't overestimate that - AFAIR trolls have default food
consumption of 9, ring does -2, so the consumption is 7 and ring reduces
only by 23%. If you have sth better I'd not bother about the ring except if
you run off the food (but there is plenty of monsters and Zin doesn't like
them so no problem I guess).
> + Level 14 Dodging
Depends on how heavy it is, for -2Heavy armour, you lose 1.4 * 2 = 3EV =
6 levels of dodging skill and gain the rest 8, resulting in +4 to evasion
stat, so not bad finally.
For your Storm Dragon Armour -5EV, you lose 1.4*5 = 7 EV = 14 levels of
evasion skill, so you'd not have *any* bonus from the skill, and in
addition AFAIK it will not raise when you will have heavy armour worn. So
all the exp you spent for it is wasted (that's exactly the Troll/evasion
problem I discussed with Tina).
I'd turn everything off to save exp points for the armour skill, that
developes both during fighting and during running, so it's wise IMO to have
some spare points everytime. It's much easier actually to raise Armour that
i.e. your Axes skill (as the difference in levels in high: 16 and 5).
Nice stuff except space distorting and inefficient meat digestion. Be
careful as controlled translocations give you magic contamination, that
probably will ruin a little your collection if you will not protect it.
Loonie
Respondit Pilatus quod scripsi scripsi.
http://www.crawl.iconrate.net
Seems I will have to do it. The problem is that using them costs
me piety.
Sure.
Space distortion isn't so much troublesome as I can control it.
I didn't start glowing yet; are You sure that mutation induced control
contamintes me to?
Regards,
Tomasz
> contamintes me to?
Yeah, little amount (one point), I'm not quite sure if you will eventually
gain sufficient contamination (contamination wears off over time).
If contamination "decides to work" you have 20% chance for random mutation
and 80% chance for bad mutation, so the risk is rather high IMO. If
contamination will be active I'd try to get rid of one of these two
mutations.
Loonie
