How to print all C drive directories
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I'd like to learn how to make a hard copy of list of all directories on my C
drive. I would use this to help ensure that (2) computers have the same files.
Can you advise whether this is possible?
Regards....
anonymous reader
In news:69DA70CA-2EE4-4E72-BA89-172A160B0161@microsoft.com,
anonymous reader <anonymousreader@discussions.microsoft.com>
typed:
> directories
> on my C drive. I would use this to help ensure that (2)
> computers
Of course it's possible. Here are three ways:
1. Go to a command prompt and issue the command
dir [drive:folder] > c:\tempfilename (you can use any name and
put it in any folder you want)
Then open notepad, open tempfilename, and print it from there.
2. Go to
http://support.microsoft.com/default.aspx?scid=kb;EN-US;Q321379
and follow the instructions there.
3. Download and use any of the several freeware/shareware
utilities that can do this, such as the popular
http://www.karenware.com/powertools/ptdirprn.asp
Ken Blake - Microsoft MVP Windows: Shell/User
Please reply to the newsgroup
Start | <cmd>
>cd c:\
>dir /s > alldirs.txt
Hi,
Open a command prompt (start/run cmd), go to the folder of choice.
Run "dir> file.txt". This will create a text file of the contents of the
folder that you can open in notepad for printing or saving.
If you wish to add the contents of the subdirectories, run "dir
<drive><folder> /s> file.txt".
You may find this useful:
HOW TO: Add "Print Directory" Feature for Folders in Windows XP [Q321379]
http://support.microsoft.com/?kbid=321379
If you head to google.com and search on "free directory printer", you will
also find many other useful tools.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"anonymous reader" <anonymousreader@discussions.microsoft.com> wrote in
message news:69DA70CA-2EE4-4E72-BA89-172A160B0161@microsoft.com...
> C
> files.
> Regards....
> anonymous reader
Thanks for the quick, and knowledgeable, advice.
> Regards....
> anonymous reader
This is better than using a $35 fee-based Microsoft answer. Thanx again.
> Regards....
> anonymous reader
