How To Tell IF My Cable Is Plenum Grade?
Chemical
57
Hey Everyone,
I was looking at my ethernet cable today and was woundering if there was a code or specific number that will specifie if it is Plenum or not.
Thanks.
Plenum tends to be stiffer than your standard non-plenum grade cabling.
On top of that, it should have Plenum stamped on the side with the coding.
It tends to cost a lot more and isn't something you normally find in your standard stores - most of the time you'll need to go to a cable supplier to pick it up.
If your cable is Plenum it will be marked with a "CMP" or"CL2P", If the cable is not Plenum it will be marke "CMR"
INNOVATIVE ELECTRONICS AND COMPUTING
