I'm rather in a pickle. Last year my HP died. I took it to a local repair shop and they said the power supply was dying but that something else was wrong but they couldn't find it. They mentioned it could be the CMO battery but they couldn't find it.
I admit I didn't give them a lot of time, they had it for 3 or 4 days but I can't work without it. Because it was so old I decided it was just best to buy a new pc. I had them go ahead and replace the power supply so I could get a few more days out of it while I waited for a new pc to arrive. However it still had trouble starting up. So once I got it home I just left it on.
And now that new PC is having issues so it's currently in the shop. So I decided to try poking at my old pc to see if I can't get it going while I wait for the new one to get repaired.
I found the CMO battery, it was behind my graphics card. So I replaced it, put everything back and the pc still will not start up. I double checked to make sure every plug is secure.
The lights turn on, the fan is turning, the power button glows, the gold colored cd icon flickers on briefly (apparently that's the hard drive id? ) I can hear soft wooshing (this pc has ALWAYS been very loud) and then after a few moments there's a soft click and a not quite beep and it shuts off to try restarting again.
The monitor never starts up.
I did try resetting the cmos jumper pin, but that didn't seem to help at all. And yes I made sure to unplug everything and ensured I didn't have any static build up on my person.
The computer's stats:
Intel (R) CoreTM i7-3770 CPU @ 3.40GHz Ram is 12.0 GB Running Windows7 64 Bit. Graphics card is GeForce GTX 680
Is there anything else I can try to do to fix this? I do have another old pc running win 7, but it uses a different ram sadly and has an amd chip instead of intel, so I'm not sure I can just put my old graphics card in it nor the ram. (which is such a shame) It's been having graphics card issues unfortunately. The other pc is also an hp :
HP e9300z amd athlon II x 4 620 processor 2.60 ghz, 8 gig ram, 64 bit windows 7 home premium service pack 1
