So I recently built my first PC and, at least for a "my first build," I would say that it is quite the powerhouse! I am proud of it and everything seems to be working properly. I will include the specifications now...
Computer Information:
Manufacturer: System manufacturer
Model: System Product Name
Form Factor: Desktop
No Touch Input Detected
Processor Information:
CPU Vendor: AuthenticAMD
CPU Brand: AMD Ryzen 7 3800X 8-Core Processor
CPU Family: 0x17
CPU Model: 0x71
CPU Stepping: 0x0
CPU Type: 0x0
Speed: 3893 Mhz
16 logical processors
8 physical processors
HyperThreading: Supported
FCMOV: Supported
SSE2: Supported
SSE3: Supported
SSSE3: Supported
SSE4a: Supported
SSE41: Supported
SSE42: Supported
AES: Supported
AVX: Supported
CMPXCHG16B: Supported
LAHF/SAHF: Supported
PrefetchW: Unsupported
Operating System Version:
Windows 10 (64 bit)
NTFS: Supported
Crypto Provider Codes: Supported 311 0x0 0x0 0x0
Video Card:
Driver: NVIDIA GeForce RTX 2080 SUPER
DirectX Driver Name: nvldumd.dll
Driver Version: 26.21.14.3160
DirectX Driver Version: 26.21.14.3160
Driver Date: 7 17 2019
OpenGL Version: 4.6
Desktop Color Depth: 32 bits per pixel
Monitor Refresh Rate: 59 Hz
DirectX Card: NVIDIA GeForce RTX 2080 SUPER
VendorID: 0x10de
DeviceID: 0x1e81
Revision: 0xa1
Number of Monitors: 1
Number of Logical Video Cards: 1
No SLI or Crossfire Detected
Primary Display Resolution: 2560 x 1440
Desktop Resolution: 2560 x 1440
Primary Display Size: 23.54" x 13.23" (26.97" diag)
59.8cm x 33.6cm (68.5cm diag)
Primary Bus: PCI Express 16x
Primary VRAM: 8191 MB
Supported MSAA Modes: 2x 4x 8x
Sound card:
Audio device: Headphones (Arctis 7 Game)
Memory:
RAM: 16302 Mb
Miscellaneous:
UI Language: English
Media Type: Undetermined
Total Hard Disk Space Available: 3337865 Mb
Largest Free Hard Disk Block: 2301316 Mb
OS Install Date: Dec 31 1969
Game Controller: None detected
VR Headset: None detected
[FROM STEAM HELP]
Essentially I have a few questions. My RAM seems to be under performing. It is 3600 and the BIOS reads that is is indeed clocked to 3666! However, in practice it benchmarks low (In userbenchmark at least). Also, all of my system info reports that it runs at 1800 mhz??? This is just a little confusing but im sure there is a simple explanation for it. Secondly, I am rocking a Corsair H100i Platinum liquid cooler and im very happy with it...I just have no idea how it works. In my gaming laptop (my previous rig) the fans would automatically spin up or slow down in accordance with the load and temps. However, even under stress testing I hear clearly that the fans on my cooler are NOT changing speed to match workload. I do NOT want this to cause overheating issues in the future. If anybody can give me some clues here I would be greatly appreciative!
Thank You.
CPU Family: 0x17
CPU Model: 0x71
CPU Stepping: 0x0
CPU Type: 0x0
Speed: 3893 Mhz
FCMOV: Supported
SSE2: Supported
SSE3: Supported
SSSE3: Supported
SSE4a: Supported
SSE41: Supported
SSE42: Supported
AES: Supported
AVX: Supported
Windows 10 (64 bit)
NTFS: Supported
Video Card:
OpenGL Version: 4.6
VendorID: 0x10de
DeviceID: 0x1e81
Revision: 0xa1
Sound card:
Memory:
RAM: 16302 Mb
Miscellaneous:
[FROM STEAM HELP]
Thank You.
