Question I am suffering from BSOD issues for more than 2 months.
Sep 24, 2020
Hello!
I have build a new PC, here are the specs:
MD Ryzen 5 3600
AMD Radeon RX 5700 XT
MSI X570 Tomahawk
16GB Corsair Vengeance 3200
1TB NVMe SSD
Seasonic PX-750 PSU
I suffered from persisting BSOD issues, it happens several times a day regardless of what I am doing. So I started looking up what the issue might be and did everything I could. I started by reinstalling a clean version of Windows, and ended up by replacing some of the hardware, so I replaced the MoBO, RAM, SSD, and of course the GPU. Unfortunately even that didn't work. The only two things that I did not replace are the CPU and the PSU.
I don't know what to do anymore, Does anyone have any advise for me, should I try and replace the CPU or the PSU??
Here are some of the dump files from the crashed my PC had:
https://1drv.ms/u/s!AidnpLoKQpMthEB2VkNBN3gO694H?e=upQgB6
https://1drv.ms/u/s!AidnpLoKQpMthEGNlV_EMk5c0Dxi?e=ncJeO7
https://1drv.ms/u/s!AidnpLoKQpMthEPqLdyXjJdUJg2X?e=jxD2cL
https://1drv.ms/u/s!AidnpLoKQpMthETyjnjLhVL5k4yM?e=vosV4F
Thanks a lot for your help.
BSOD = faulty RAM most of the time.
The other part of the time it's a failed OC, but I have to presume you've reset your CMOS and are running everything at stock/auto.
Tell us more about this.... "SuperSonic" PSU. Did you mean SeaSonic, or EVGA SuperNova?
Thanks for your reply.
I have actually replaced the RAM sticks, but nothing changed. And yes as you said I'm running at stock.
The PSU is Seasonick PX-750 "80 Plus Platinum" (Thanks for noticing this, I'll fix it in the main Post).
