Question i have a Corsair H60 2013 edition, and a 1080 hybrid evga, I want to add a resorvoir and use a 240 radiator and 120, can i connect them?
That pump isn't strong enough to handle that much radiator with that much tubing and the block and that much resistance with that low a volume of flow.
Ever see a geisha walk? Those tiny little footsteps? That's the asetek pump on that aio. What you need is a pump that'll give you a full man's stride.
If you plan on doing custom loop, then actually do a custom loop, Franken-loops rarely work as intended or expected.
I know i understand thats why i ask but the point is that i dont want to buy a cpu block neither gpu block so can i buy a pump and put it work with those aio closes?
