Hello, I apologize in advance if my English isn't perfect.
Here is the problem:
I've been using Powerline plugs since almost two years now, to be able to get access to Internet on my desk Computer.
The router is in the living room, which is not far at all from the office, but I don't have a WiFi card in my computer, prefering to be connected with an Ethernet cable.
So the router is in the living room, and it is plugged to the Powerline, which itself is plugged into the wall. An ethernet cable from the router connects to the Powerline plug.
Then, in my office, where my Computer is, I have the second Powerline plug connected into the wall socket, and then a multiplug plugged into the Powerline. Another Ethernet cable connects this Powerline plug to my Computer.
Anyhow, everything was working fine for almost 2 years, when, on Friday afternoon, I encountered a big problem.
I have been using my computer up until the previous day, in the evening, where everything was fine.
But on Friday, as soon as I had to update games or launch a Speedtest (either with Ookla or directly using my Internet Provider's tool on the router browser's page), the whole internet shut down, Ethernet and WiFi.
After manually reseting the router many times, and seeing no change, apart from getting Internet back on my Computer for a mere 15 seconds, restarting to update my game (either on Steam, uPlay or what have you), it stopped again.
I called the Customer Service, they told me they saw that everything was fine on my side, the router had indeed some problems, but it restarted after while, and restarted to shut down few seconds later.
They manually did an update of my router, but it didn't change things.
So I got someone coming on Monday morning to check the network on my side.
In the meantime, I wanted to figure out what could be source of problem, so I started to not update or download anything on my computer, not doing a speedtest either, and indeed, my Internet was back, at least for browsing.
But as soon as a heavier download happened, it shut down.
I then used the laptop of my girlfriend, plugged it via a cable directly onto the router and started to download something, and no problem there.
Did the same but in the office, and then it shut down again.
I then moved my whole set up into the living room to be connected directly via cable to the router, and I had the same problems actually.
Secondly, I bought new Powerline plugs, more recent ones, and a new Ethernet cable, just to be sure.
And now that my computer is back in the office, and plugged onto the new cable and PWRLN plug, the problems started again, with a new pair of Powerline plugs and cables mind you.
So the problem doesn't come from the powerline plugs nor the cables then.
Oh, and downloading using the WiFi is fine.
I used the PWRLN plug from my office onto another wall socket, and not problem there neither, so I guess my electrical network encountered a problem at one point during the night between Thursday and Friday and it has now difficulties to manage big packages of data.
On Thursday evening, I think, I remember that the light of the kitchen vent died out when I wanted to open the vent.
But this light is in the kitchen, in another separate room.
Anyone could help me figuring out either what to do, what could be the problem or if there are solutions?
Knowing that I can't use my computer in the living room, as we don't have much space, we use the table there to eat, and my set up, with a widescreen, is quite imposing and takes a lot of place.
