[SOLVED] I installed a Kingston A400 960GB SSD and its not showing up in device management but does in bios
Aug 29, 2020
7
Ive installed a ssd and now it hasn't showed up in window, only bios. i can see it in device manager but not disk management. ive tried a couple solutions from the site and nothing has worked so far and im stumped.
I should mention im new to ssd installation and havent formatted it or partitioned since i havent been able to access it in windows.
enter the bios and disable secure boot and enable CSM, save and restart right back into the bios and see if it's listed now.
Also check that your sata ports are in ahci mode. If they are in raid mode then you might need to configure/format the drive in the raid bios first.
Run Diskpart from an Admin level Command Prompt
enter in List Disk
Do you see the drive there?
If it's Ok to erase the whole drive then enter in select disk x (Where x is the number of the disk from list disk)
followed by clean all
if it cleans successfully then you can exit and relaunch disk management and be able to initialize it.
Reactions: Turtle Rig
enter in List Disk
I only see my harddrive in the disk list and not the ssd
They are in ahci mode and its listed in bios but ill still give it a shot.
