[SOLVED] I need help connecting my cpu fan
Insane Potatoz
768
52
4,990
I am building a pc for the first time right now, and I ordered a fan for the cpu. The fan has a 4 pin connector and the motherboard a 5 pin! How can I get these to work? Is there an adapter or something? Thanks.
I got an entire cooler. Heat sink and fan. My motherboard is the Dell optiplex 9010 motherboard and my cooler is just an intel socket 1155 cooler
Dell uses proprietary 5-pin fan connector.
You could have got a Dell fan or compatible fan for Dell Optiplex 9010 .
https://www.newegg.com/p/1YF-00B0-00200
Since you already purchased a standard 4-pin fan then you should get a Dell compatible 5-pin to 4-pin fan adapter.
You could get one from Amazon or eBay and many other places.
https://www.amazon.com/dp/B073XJV5L9/
https://www.ebay.com/i/323059517018
Reactions: Insane Potatoz
Some ppl are manually adept at such things, some are not and don't want to risk destroying the one thing that does work, the new cooler. A wiring adapter is a safer bet for them.
Also, many newer coolers are coming with sleeved or all black wires and one wrong move can have ugly results.
Latest posts
