Hello there, wasn't sure if this should be posted as a question or discussion, but ultimately decided the former as that is what I originally wanted this post to be. It might be a slightly lengthy post, because I have a little explanation to do and a lot of pieces to gather opinions about.
To start off with a little explanation, a couple days ago I broke my the CPU socket on my motherboard trying to clean it due partly to laziness and partly to a poorly designed case I've now tossed into the trash. This has led me to owning a CPU, a dying GPU and PSU, an 8GB stick of RAM and my HDD. Sort of thankfully I had been planning almost a complete overhaul of my PC next month, of everything but my motherboard, RAM, hard drive and WiFi card. The fact I now have to replace my motherboard as well is why it's sort of thankful.
I was planning to buy and put all the parts together one by one, but the whole ordeal has sort of tired me out and now I've changed my mind. I found a computer that has a number of the parts I was already planning to buy, but I'd like some opinions on some/all of the parts before I make a final decision so I don't waste any of what is now my emergency PC budget (which is around £1500/$2000/€1600)
This is the PC I'm currently looking at buying: http://www.cyberpowersystem.co.uk/saved/2579359
Hopefully it loads for everyone, but I'll list it's parts in a comment so as to not drag this post out anymore in case it doesn't.
My main questions and issues are as follows:
First, I am unsure what really constitutes as a good case, except for being spacious. I did some looking and the Lian Li Lancool II seems like not only a popular choice, but a solidly designed one too (if a little heavy). Thankfully it was one of the customisable options for this particular computer, but if anyone has any better options feel free to suggest them for consideration.
Second, is the liquid cooling option that I selected any good? I know nothing about liquid cooling so I pretty much need all the help I can get for that. My initial plan was to buy a Noctua NH-U12S 55 CFM CPU Cooler for the i7-9700k I was planning to buy to replace my i3. I'm still tempted to remove the liquid cooler and buy the Noctua seperately to use, but thermal paste is part of what got me into the mess that broke my motherboard in the first place so I'm also not too fond of the idea.
Third, is the MSI motherboard chosen a good fit? I was planning on getting a Gigabyte Z390 as they haven't steered me wrong, but none of their boards are an option, so I picked the top choice of the MSI boards as I really don't know much about those.
Fourth, are there suggestions, additions or replacements that anyone might have towards my builds in an attempt to make it better?
Some after notes: The i7-9700k is the CPU I want, I was already planning on buying it originally so it works perfectly for me. I plan on using it mostly to game, but at 1080p and high settings with 60 frames, mostly with games like Red Dead Redemption 2 as the most intensive game I play, and Risk of Rain 2 as the "least" I suppose (I don't have a 4K moniter nor the eyesight for one so I'm not interested in all that).
I checked the GPU options for the configuration and didn't see the RTX 2060 which is my choice GPU, so I plan to buy it seperately and install it once I have both the PC and the GPU delivered. The 8GB RAM I have chosen is exactly the same model and speed as the 8GB stick I currently have sitting around, and I'm not really looking for more than 16GBs currently.
I already have a 1TB HDD from my old PC and I don't really need more than 3TB totals so I'm not looking for more there. And I have an external WiFi card sitting with the rest of my stuff that I can plug into my new motherboard in the case it doesn't have onboard wireless networking.
Thank you in advance for any and all help, and I'll try my best to reply as quickly as possible, as I don't really want to be without a PC for too long.
