Question I NEED HELP : FREEZING IN STEAM GAMES
Mar 1, 2020
Hello,
I recently built my own PC with pretty high end parts. I can run Call of Duty Modern Warfare at Ultra and High graphics no problem. However, whenever I try to play a game on Steam, the game will have intermittent freezing. I have tried everything I've seen on multiple different forums, I've reinstalled windows onto a clean drive, I've even changed graphics cards to see if that was the issue. I cannot for the life of me figure out what is happening, please help.
Motherboard: B450 Tomahawk
CPU: Ryzen 2600
GPU: EVGA 2060 Black
RAM: 16GB Corsair Vengeance RGB Pro 3600MHz
PSU: Corsair VS650
high end build except the psu
ssd or hdd?
cpu/gpu temp and usage?
ram/hdd/sdd usage?
Windows and the games are installed on the SSD, I have more than 800gb of space on the SSD. CPU is at 32.5 C, TDC is at 27% of 60A, EDC is at 99% of 90A. GPU is at 37 C. Both the CPU and GPU are running lower than 5% in task manager. Also on PCPartPicker this setup only calls for 334 watts or something like that.
