I need help. I want to build a gaming pc of INR 40000.
Kanavk
48
I need to build a gaming pc fo myself. I have a LCD TV which is not in use and I'm gonna use it as my monitor. Please provide me with suggestions for specifications.
you should have 8 gb ram to max out games so 8 gb is needed. And don't even think of i3. Get fx 6300, it's 2-3 times better than i3 with same price tag.
And there won't be any bottleneck with fx 6300 and hd 7870. So don't worry. Fx 6300 and hd 7870 are really great choice for you.
CPU : Intel i3-3220 , 3.3 GHz dual Core , Rs. 7500
GPU : ZOTAC NVIDIA GTX 650 Ti amp Boost 2GB, Rs. 10000.
RAM : Cosair Vengeance 8GB, 1600MHz (4x2), Rs. 7600
Motherboard: ASRock 970 Extreme 4 Motherboard, Rs. 8000/ ASUS F2A85-M-LE, Rs. 6000
PSU : Corsair VS 550, Rs. 3400
HDD : WD Caviar Blue 1TB, Rs. 4200
Cooling fan: cooler master hyper tx3 evo cooling fan, Rs. 1500
TOTAL : Rs. 45000 (Approx)
that doesnt look compatible
and the total is not arithmetically correct
u are forgetting the cabinet again
You sure about the amd fx6300 because everyone is saying i3 or i5 is better than amd fx 6300 in gaming performance, but syill you're the expert 😉 I got about everything you said but I'm gettin confused because everybody doesn't have the same view about whether it is intel or amd.
Oh stop that i3 crap. It's a piece of junk in gaming. Yes, it has 4 logical processors but basically it's a dual core with 2 physical processor. It's no good for you in gaming than fx 6300 as fx 6300 has 6 core and i3 has only 2.
That 4 logical processors are not much of use in gaming.
You are you considering i3 anyway? when you can get a 2-3 times better fx 6300 in less price. You are just paying more for the price.
Please stop recommending him i3 over fx 6300. I'd buy fx 4300 over i3 as you can max out games like crysis 3 and far cry 3 with fx 4150 while i3 can barely run them on medium. So fx 6300 is waaay better option.
I am sure a lot of senior experts will agree with me too. And yeah fx 6300 is equall to an i5 4440.
It will even be better on games which are optimised for 6-8 cores.
