[SOLVED] I need help Regarding My New PC Build
aniruddha_datta
Commendable
Jan 22, 2019
17
Hello Guys it's that happy time of my life, My first Full PC Build i have a budget of 500-660$ and these are the specs i think would be perfect i just need help of you guys with my GPU and to check if the build is any good. Be advised i like to keep my GPU On the Nvidia side because of the shadowplay experience. Also can a Run a GTX 1660 with a HDMI to VGA converter i have a 6-7 year old VGA Monitor which Would run a GTX 1050 easily with a converter i have a strict budget and i want to upgrade the monitor a but later because i am planning to buy a 120hz monitor but not now, Yes is it even worth buying a 120hz monitor with my given specs below?
CPU:- i5 9400f
Ram:- HyperX Fury Black 8gb
Motherboard:- Gigabyte B360M LGA1151
HDD:- WD Blue 1TB
SSD:- Kingston 240gb
PSU:- Corsair vs450
GPU:-?(no idea maybe the 1650 or the older 1070 also the 1660 looks nice)
Please help me out with my new build . Also here are my old PC specs which i upgraded from a Old Office PC.
CPU:- i3 3220
GPU :- GTX 1050 2gb
Motherboard:- old LGA1150 i forgot the slot forgive me if i am wrong.
RAM:- 8GB DDR3
PSU:- old 400Watt PSU
HDD :- WD Blue 1TB(almost new)
Thanks.
The i5 9400f is cheaper in my country and the GTX 1660 Super costs a minimum of 300$ every PC Part is High-priced in India . What should i do
Oh God..why are the prices so different in India...I would still move heaven and earth to get the 1660 Super but failing that then the 1660.....the 9400F is more than good enough for gaming...
This would be better in pretty much every way:
Cheaper cpu with twice the threads near identical performance and can be overclocked.
Twice the ram
Much faster and more reliable SSD
Better quality PSU
Gpu faster than the regular 1660 you originally planned. (the 1650 is just a overpriced pos not even worth considering)
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor ($117.58 @ OutletPC)
Motherboard: Gigabyte B450 AORUS M Micro ATX AM4 Motherboard ($85.89 @ OutletPC)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 Memory ($54.99 @ Newegg)
Storage: Crucial P1 500 GB M.2-2280 NVME Solid State Drive ($66.85 @ OutletPC)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive (Purchased For $0.00)
Video Card: EVGA GeForce GTX 1660 Super 6 GB SC ULTRA GAMING Video Card ($229.99 @ Amazon)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case ($44.99 @ Amazon)
Power Supply: Corsair CX (2017) 450 W 80+ Bronze Certified ATX Power Supply ($53.88 @ OutletPC)
Total: $654.17
Generated by PCPartPicker 2019-11-02 06:33 EDT-0400
This was tough and I went over a little bit by around $48.75. This is a Intel 9400F builkd with a GTX 1660 Super which is great value as it is fractions of the 1660Ti and makes the Ti obsolete. In my opinion the 9400F at this budget just wins on FPS and with the Z390 motherboard you can upgrade in the future all the way to a 9700K...PS I am hoping you have your old case...I am sure others will provide some better suggestions but this should give you options...
PCPartPicker Part List: https://pcpartpicker.com/list/qFthyk
CPU: Intel Core i5-9400F 2.9 GHz 6-Core Processor ($147.88 @ OutletPC)
Motherboard: Gigabyte Z390 UD ATX LGA1151 Motherboard ($100.89 @ Amazon)
Storage: Western Digital Blue SN500 500 GB M.2-2280 NVME Solid State Drive ($64.98 @ Amazon)
Power Supply: SeaSonic S12III 500 W 80+ Bronze Certified ATX Power Supply ($49.99 @ Amazon)
Total: $648.72
Generated by PCPartPicker 2019-11-02 06:48 EDT-0400
Twice the ram
Better quality PSU
Total: $654.17
Reactions: aniruddha_datta
