[SOLVED] I need help!!! Screen is black not booting!!!
Oct 7, 2021
Recently I enabled Secure boot on my b450m ds3h intel MOBO through the bios and now my Computer will turn on and of (maybe because I removed my RAM) and it also Just will not post. I really need help, some videos say to Take out my CMOS for a few then put it back in. Any ideas or past experience with this problem.
Hey there, same issue just happened with myself installing win11
Remove the CMOS battery for 30 seconds (this will reset all your bios settings)
mic you are attempting to install windows 11 you do not need secure boot enabled, use the windows 11 install assistant to upgrade
