Question i need help with my gaming pc undeperforming
Mar 28, 2021
22
i recently build a gaming pc but it seems to be underperforming in games
ryzen 5 3600
rtx 3060
16gb 3200mhz
asrock b450m-hdv r4.0
case Silverstone fara r1
antec 750 wt 80plus gold power supply
144hz monitor
vsync disabled
did ddu many times
should run valorant at 300+fps minimum but gets 200 and drops frequently instead
please if someone could help with getting most out of my pc
By underperforming is this issue seen only on the Valorant? If not, what other titles have you taxed the system with? Which BIOS version are you currently on for your motherboard? What OS version are you on?
Antec is the brand, 750W is the wattage, while 80 plus Gold is it's efficiency rating. It tells us nothing of it's model. Please include the age of the unit as well.
All the components you listed seem very good.
Are the people that are getting higher frame rates running the same cpu?
Storage devices? Some nvme drives are slower than others, same for hard disk drives. ie: read and write speeds may be lower
Another thing could be you are running other programs at the same time, recording your game session could slow it down, other people in your house using the internet at the same time could be affecting your internet bandwidth.
Last but not least, the people that are getting better frame rates may simply have a better internet connection. That's very difficult to determine though because there are so many ISP's and your geographic location comes into play also. Perhaps you could compare your ping times and latency to the game server with your friends, to determine if that may be a factor.
All in all I think any frame rate above 60 is hailed to be very good.
{GoofyOne's 2c worth}
people have almost the same configuration and different motherboard which shouldn't be problem to my knowledge and different ram mhz they test at 3600 and mine is 3200
Are you sure that's not the explanation right there - ram at 3600 MHz vs 3200? Ryzen likes fast ram.
