1st of all my PC Build:
AMD Phenom ii X4 965BE 3.4GHZ.
4GB DDR3 RAM
Graphics card: ATI Radeon HD 5770
PSU cooler master GX-550W
Case cooler master 430 Elite which has got 2 120 MM fan one intake and one outlet....
as the AMD CPU cooler(at normally 44 degree Celsius 7k RPM) makes noise like a jet engine i would like to change it with a after market one which has 120MM Fan in it and which will reduce temp. at low as possible plz suggest one....
cooler master Hyper 212 fits in my budget
http://www.coolermaster.com/product.php?…
can anybody tell me
1) With cooler master hyper 212 cpu cooler how much i can over clock my cpu safely???
2)temperature drop with after upgrade??
..thank you very much
4GB DDR3 RAM
can anybody tell me
