Question I purchased a gpu for my build finally, the included PCI-E cable with my power supply doesnt fit the gpu. What cord do I buy?
What doesn't fit?
The PSU has
4 x 6+2-Pin PCI-E Connector
So, there are 4 individual connectors that would work for that GPU. You take the 6+2 and join them together = required 8pin.
If it doesn't fit, ensure you're orientated the correct way... And ensure you're looking at the correct cable - that PSU has a solid 8pin EPS in addition to the standard 4+4, so you might actually be trying to fit a CPU/EPS connector into the GPU .... That won't fit, nor should it.
Which cable are you talking about. Your current PSU has 4 x 6+2-Pin PCI-E Connectors for the GPU. That card only requires a SINGLE 8-PIN.
