i3-8100 vs i3-8350k, does the 8350k max out on load?
Sep 27, 2018
58
I am going to build a new pc and i am thinking of bying an i3-8350k. I first thought of bying an i3-8100, but I prefer 8350k, because it has base 0.4ghz more, can be overclocked up to 5ghz and has +2mb cache memory. My friend told me that i should not buy i3 8350k because it is unlocked, which results in the cpu's cores maxing out on load. So, my questions are:
1) Do unlocked cores max out on load much easier than the locked ones?
2) Can the pc motherboard or/and its ram affect cpu's load?
3) Does the i3-8340k actually max out on load easier than the i3-8100?
4) Is Cryorig H7 (cooler) good enough for the i3-8350k
PC specs:
gpu : Gigabyte GeForce GTX 1060 6GB
Motherboard: Z370 aorus gaming 5 (rev 1.0)
PSU : Corsair CX series CX650
HDD : Western Digital Blue 3.5" (7200 rpm)
Ram : HyperX Fury Black 8GB 2666 Ghz
Case : CoolerMaster MasterBox 5 (Window)
That's not how it works at all. The non-K CPUs are literally throttled down. So, they are artificially slowed down by the manufacturer. The unlocked K-series processors have greater potential because they aren't artificially slowed down. They are typically built on better silicon too. Which is what allows them to have the overclocking head room. Plus, they are faster without even being overclocked. The CPU with more "wasted" potential would be the non-K CPU.
FYI, not to be rude, but your friend really doesn't sound like he knows what he's talking about.
You realize turbo is a stock feature and perfect safe, right? You'd rather buy an unlocked chip (and presumably overclock).
While overclocking isn't exactly dangerous... there are some (minor) risks involved. Whereas turbo is a stock feature and perfectly safe.
No. Just no. That's not how anything works, remotely. In a very simplistic sense, at stock that added 'speed' doesn't 'exist' until/unless you overclock.
Ultimately, you've been given viable options and rationale as to why.
If you're bound and determined to buy an 8350K &/or wish to follow your friends misleading advice, by all means do so.
.....and I think you should, based on the information provided.
I think we're at an impasse :lol:
Of course, you're free to buy whatever you want - I'm only trying to provide a recommendation.
TBH I am really confused... I don't know which one I should buy. On the first hand the i5 has 6 cores and 6 threads, less power consumption and 1mb cache more. On the other hand the i3 has more base clock speed and can be overclocked without reaching high temperatures compared to others. I guess that I dont care that much about power consumption and the 1 bonus mb cache , but having 6 cores and 6 threads sounds like sth that is important. The i3 is definetely better at things that don't need more than 4 cores and I dont actually play games and use software that needs those 2 more cores. I dont know if this will be true in the near future, but all games etc. don't actually neccessarily need more than 4 cores, although 4 CPUs with 4 cores exist for many years. I AM REALLY CONFUSED RIGHT NOW....
As I posted earlier, it's 100MHz difference (before overclocking) vs the stock turbo boost of 4 cores on the i5-8400 that won't make any noticeable difference in performance in tasks that require 4 cores or less.
No, it's not. At least, not conclusively. Might have a very marginal edge in some tasks, but for all intents & purposes, they'd perform identically.
i3-8350K = $169
You'll need a cooler. Say $20 minimum
To overclock, you'd need a Z370 board. Minimum of $80
Not a great cooler, just serving the example:
CPU: Intel - Core i3-8350K 4GHz Quad-Core Processor ($169.00 @ Amazon)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($19.99 @ Newegg)
Motherboard: Gigabyte - Z370P D3 ATX LGA1151 Motherboard ($79.99 @ Newegg)
Total: $268.98
Generated by PCPartPicker 2018-09-28 17:47 EDT-0400
OR
i5-8400 = $200
B360 motherboard = $60 or H370 = $65
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor ($199.89 @ B&H)
Motherboard: MSI - B360M GAMING PLUS Micro ATX LGA1151 Motherboard ($59.88 @ OutletPC)
Total: $259.77
Same or better performance, for ever so slightly less money.
You're really comparing overclocking potential vs 2 added cores.
To me, it's a no brainer.
Your friend watches too much crappy utube.
For an i5 8400, the H7 would work fine, or better yet, the H5 universal, if you have the clearance in your case. Turbo is automatic. You can either enable or disable turbo, via the bios. Default is turbo on.
Also, I would stop taking PC advice from your friend. His knowledge of how things work is not something I would consider reliable.
I was going to buy everything for my pc in the middle of October, but I found out that the i5-8400 was not available in any shop in my city (because Intel has a problem with 8th gen CPUs), and that it would be available much later( I could buy one at some certain shops, but they sell this CPU 100€ more). As a result, I had to quickly choose if I want to buy the i5 8400. And I think i made the right decision which was to buy the i5. I would normally buy the i3 8350k but I guess that would be a mistake. The i5 is cheaper, has 2 cores and 2 threads more (which makes it more future proof and better at multi tasking), has better temperatures and 1 mb cache more. The i3 has 0.2 ghz base clock speed more (if the i5 is on turbo, which is the whole point of this cpu), and can be overclocked up to 5 ghz. TBH I wouldn't ever overclock the i3, and if i wanted to overclock it in order to notice any difference, i would have to buy a liquid cooler. Also, the i3 reaches 100% usage pretty easily, which results into screen stuttering and the cpu not being able to handle anything more. The i3 and i5 are actually the same at gaming, but the i5 is way better at multi tasking and editing. The i3 is only worth it if going to be overclocked and slightly better at single core and quad core stuff. Whatever, I tried to find the i5 in my city (with a good prize) , and it actually is being sold in only one shop, which has only 1 copy of it. I have booked it and will buy it on Monday.
Generally speaking 60Hz High settings is 6GB 1060 or 8GB RX580 territory.
Beyond that, 1070, 1070TI or Vega56.
Titles vary in requirements though, so that's just a solid general guideline.
With some tweaks (say "High" opposed to "Ultra") a 6GB 1060 is more than capable, generally speaking, of 1080p 60-75Hz
