Just looking for help choosing a mobo to overclock an i5 4670k. I'm looking for the cheapest possible but still good enough to get the job done and be reliable. Ty
It is not. Cheapest Asrock you should be looking at is the Z87 extreme 3.
As for your CX750 power supply, you need to get a 550W power supply that is more stable and of higher quality, the CXs are decent for low budget systems, but not if you wanna OC.
