I have built my first gaming rig about 8 months ago with an i5 8600K on an Asus ROG Strix Z370-E Gaming Motherboard with a 120 AIO from cooler master.
Note that I have tried a complete stock use of the cpu @3.6 GHz and the temps are shockingly same for stock and my AI tweaked boost of 4.3 GHz at all cores.
Tested Cinebench R15. Score at 4.1 to 4.3 GHz on all cores was 970 around. Temps according to Asus's own software and core temps was max 89C for a few moments on 1 core. Res of the cores stayed below 86C. Overclocked to 4.7 GHz where I scored 1090 and the temps reached 99C for a moment on 2 cores. I also tested my cpu in Cinebench R20 and the score is 2477 at 4.1 to 4.3 GHz but in this test the temps reached max at 97c on core 0 and other 5 cores stayed below 95C.
When idling all cores stay at around 39C to 41C. All of these results are from my 120 AIO with a push-pull configuration. I tried only push and only pull too but then at 4.3GHz I reached even 95C. So I see a massive change in temps with this push-pull system. My chassis is cooler master masterbox lite 5 RGB and it has 1 rear exhaust 3 front intake of which 1 is used for CPU cooling in push method and another 1 fan on the other side of the radiator to do the pull method.
I wish to know if the temps are abnormal and if the scores look normal to experts! My ambient temperature is around 27C to 32C. All of the fans used in my rig are 120 mm fans. The 1 pushing on my AIO came with my AIO so it is running at 2200 RPM. All the other fans are running at 1300RPM. The pump itself is running at max speed. I don't have air conditioner to cool down my room. Just 1 ceiling fan which is noisy enough to not let me hear anything from my CPU fan's speed.
Thanks in advance for any suggestions or comments!
