hello, i have been a long a time reader and am sure i have read just about everything i could possibly squeeze into my head regarding the specific components and settings of my setup. Heres my problem, i can get a solid stable overclock to 3.465 ghz with only 1.21 cpu voltage. Thats a BCLK of 165 with 21x multi. As soon as i up the BCLK just one point to 166, i crash instantly upon opening Prime 95. It is not a heat issue, With HT on, i my max core temp is 67 degrees C. Giving it a small voltage bump , like 1 or 2 notches brings me enough to raise my BCLK to 172. Same temps. I have also tried setting the cpu multi down and have gotten the BCLK to 220 with no problem. So now , i have tried several different voltage combos to use a 173 BLCK. Even, went upto 1.4vcore and 1.35 qpi and upon doing that, i get the continuous reboot cycle... This really freaked me out. So i hard shut it down, waited a moment, let it reboot and it loaded the secondary BIOS . I have my MEM multi set at 6x to keep that out of the equation. I am pretty new to this, but have a somewhat decent understanding. So basically, how can i get a decent OC with below stock voltages, but cant even reach 3.7 with increasing the voltages by such a large degree. I only intend to reach 4.0ghz to get there for the sake of seeing my own cpu's capability, but not leaving there. I know there is alot of info i have left out, but if we could just start with this and work our way to get some ideas would be greatly appreciated. I have read so much , i just now finally decided its time to post and hopefully find someone with similar components and or problems. Thanks Again! ~dan.
Gigabyte x58 ud3r mobo bios f3 or f4... will double check when i get home
Core i7 920 C0 stepping
6gb OCZ 1333
EVGA GTX260 stock speed
Corsair 750tx
Noctua u12p cpu cooler
WD 500GB caviar black
6gb OCZ 1333
Corsair 750tx
